Shop the Holiday Gift Guide
Ask a Question
There are no questions. Be the first to ask a question!
Printed Parts STL
Bear Frame 2.1 for MK3(S)(S+) STL files: bear21_mk3-3s_stl.zip
Bear Frame 2.1 for MK2(S) or MK2.5(S) STL files: bear21_mk2-2s-25-25s_stl.zip
If you have the early Full Bear 2.0 for MK2(S)/2.5(S) (shorter frame than Bear 2.0 MK3) you will need to use special parts. All details and STL are available in the optional parts -> bear_2.0_upgrade_mk2-2s-2.5-2.5s.
Print Settings
Read the print settings here.
WARNING: It is important to follow the recommended print settings and to calibrate your extrusion multiplier before printing the parts (for each and every spool that you use). Check our calibration guide: Extrusion multiplier and filament diameter
Compatibility
This Bear Frame Upgrade 2.1 is compatible with the Full Bear Frame Upgrade 2.0 MK3 frame. If you do not know which frame you have please check our FAQ here. The 2.1 version needs extra hardware (screws, nuts, washers, dowel pin), check the bill of materials for more details. You can also order hardware upgrade kit from our distributor websites.
If you have a Full Bear Frame Upgrade 2.0 MK2S or MK2.5 frame you can find compatible parts in the optional parts section below.
The new Y and Z axis are not compatible with any of the existing Prusa or Bear 2.0 parts. You have to update all parts from Bear 2.1.
The original Prusa firmware is compatible with the Bear Upgrade 2.1 only if you use the Original Prusa extruder and X axis. If you use the Bear upgrade 2.1 frame with BearExxa, BearMera or Bondtech extruders you will need to use custom firmware.
Assembly guide
Link to the assembly guide is available on top of this page.
Bill of materials
Read the BOM here.
Optional parts
Official optional parts
Community's option parts
Frequently Asked Questions
Read the Bear FAQ here.
CAD files and mechanical drawings
Bear 2.1 frame for MK3(S)(S+) CAD files and mechanical drawings: bear21_cad_drawings_files.zip
All source files (the complete GitHub repository): Go the to latest release note and in the bottom of the release note, under the Assets, click on "Source code" (you can choose between zip and tar.gz files).
Release notes
Read the latest release note here.
Greg Bear
8,773 Reputation
35 Guides authored
Past 24 Hours: 44
Past 7 Days: 61
Past 30 Days: 61
All Time: 61
