Ask a Question
There are no questions. Be the first to ask a question!
Background
Bang & Olufsen released the Beosound Explore in April 2021 as its adventure-oriented rugged portable bluetooth speaker. The Type II hard-anodized aluminum shell—manufactured in Denmark—uses a vertical rib structure for scratch and impact protection, and the speaker carries an IP67 rating. It was the first B&O product to include an integrated carabiner, complementing a replaceable flexible strap.
True360 omnidirectional sound comes from two 1.8 in full-range drivers driven by two 30 W Class D amplifiers, with a 56 Hz–22.7 kHz frequency range. Two Explores can be stereo-paired, and EQ presets are customizable through the Bang & Olufsen app. Fast pairing is supported via MFi (Apple), Google Fast Pair, and Microsoft Swift Pair, with multipoint connection to two devices. The single USB-C port handles both charging and wired audio streaming. Early units received a firmware update improving battery reporting; checking firmware via the B&O app is a useful first troubleshooting step.
The Beosound Explore retails for $299 and is available in Black Anthracite, Grey Mist, Green, or Bonfire Orange. There's also a red Ferrari Edition for $349.
Identification
The Explore is a compact cylinder, 81 mm in diameter and 124 mm tall, weighing 631 g (637 g with carabiner), with a ribbed aluminum barrel, a rubber base, and a fabric top housing recessed, glove-friendly buttons (power, Bluetooth, play/pause, volume) under a rubber overlay. The carabiner lug and B&O logo distinguish it from other small cylinder speakers. The B&O item number is printed on the base label.
Model numbers by color:
  • Black Anthracite: 1626000
  • Grey Mist: 1626003
  • Green: 1626004
  • Chestnut: 1626005
  • Navy: 1626012
  • Bonfire Orange: 1626037
  • Ferrari Edition (red): 1626028
Technical Specifications
  • Drivers: 2 × 1.8 in full-range; 2 × 30 W Class D amplification
  • Frequency range: 56 Hz – 22.7 kHz; max SPL 91 dB @ 1 m
  • Battery: 2,400 mAh Li-ion; up to 27 hours at typical volumes; ~2 hour charge at 5 V/2–3 A
  • Charging/wired audio: USB-C
  • Wireless: Bluetooth 5.2, SBC codec; multipoint (2 devices); stereo pairing between two Explores
  • Water/dust resistance: IP67
  • Materials: Type II anodized aluminum, polymer, fabric
  • Dimensions: 81 × 124 × 81 mm; weight 631 g (637 g with carabiner)
Additional Information
Carsten Frauenheim
171,244 Reputation
442 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,303 Guides authored
Past 24 Hours: 11
Past 7 Days: 29
Past 30 Days: 100
All Time: 215
