Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Background Infromation
Introduced October 9, 2025, the P2S is the direct successor to the BambuLabs P1S. This new iteration in the P Series of 3D printers features a 5-inch touchscreen, quick-swap nozzle, and improved airflow control for different printing scenarios, and chamber temp control.
Technical Specifications
General Information
- Printer Type: Fused Deposition Modeling
- Build Volume:
- 256 mm
- 256 mm
- 256 mm
- Cassis Material: Plastic and Steel
- Outer Frame: Plastic and Glass
Physical Dimensions
- Phyical Dimensions:
- Length: 392 mm
- Width: 406 mm
- Height: 478 mm
- Net Weight: 14.9 kg
Toolhead
- Extruder Gear Material: Hardened Steel
- Nozel Material: Hardened Steel
- Max Nozzle Temp: 300 °C
- Included Nozzle Diameter: 0.4 mm
- Supported Nozzel Diameters:
- 0.2 mm
- 0.4 mm
- 0.6 mm
- 0.8 mm
- Filament Cutter: Built-in
- Filament Diameter: 1.75 mm
- Extruder Motor: Bambu lab High-percision Permanent Magnet Synchronous Motor
Build Plate
- Build Plate Material: Flexible Steel Plate
- Included Build Plate Type: Textured PEI Plate
- Supported Build Plate Types:
- Textured PEI Plate
- Smooth PEI Plate
- Cool Plate SuperTack
- Max Heatbed Temp: 110 °C
Speed
- Max Speed of Toolhead: 600 mm/s
- Max Acceleration of Toolhead: 20.000 mm/s2
- Max Flow for Hotend: 40 mm3/s (250 mm round model with one outer wall; Bambu Lab ABS @ 280 ℃)
Air Filtration
- Filter Type: Activated Carbon
- VOC Filtration Support: Yes
- Particulate Matter Filtration Support: Yes
Cooling
- Part Cooling Fan: Closed Loop Control
- Cooling Fan for Hotend: Closed Loop Control
- Auxillary Part Cooling Fan: Closed Loop Control
Supported Filaments
- PLA
- PETG
- ABS
- ASA
- TPU
- PA
- PC
- PVA
- PLA-CF
- PETG-CF
- ABS-GF
- ASA-CF
- PA6-CF
- PA6-GF
- PAHT-CF
- PPA-CF
- PET-CF
Sensors
- Camera: Built in Camera
- Resolution: 1920 x 1080
- FPS: 30 fps
- Door Sensor Support: Yes
- Filament Run Out Sensor: Yes
- Filament Tangle Sensor: Yes
- Filament Odometry Support: Yes w/ AMS
- Power Loss Recovery: Yes
Electrical Requirements
- Voltage: 100-120 VAC / 200-240 VAC, 50/60 Hz
- Max Power: 1200 W @ 220 V / 1000 W @ 110 V
- PLA Steady-State Power: 200 W @ 220 V / 200 W @ 110 V (PLA Printing)
Operating Environment
- Operating Temp: 10 °C - 30 °C
Electronics
- Touchscreen: 5" 854 x 480 Touchscreen
- Storage: Built-in 8 gb EMMC & USB 2.0 Port
- Control Interfaces:
- Touchscreen
- Mobile App
- PC App
- Motion Controller: Dual-core Cortex-M4 & Single-core Cortex-M7
- Application Processor: Quad-core 1.5 GHz ARM A7
- Neural Processing Unit: 2 TOPS
Software
- First Party Slicers: Bambu Studio
- Third-Party Support: Supports any third-party slicers that exports standard G-Code, but some advanced features might not be supported.
- Super Slicer
- PrusaSlicer
- Cura
- Supported Operating Systems:
- MacOS
- Windows
- Linux (Ubuntu & Fedora)
Communication
Network Control
- Ethernet: N/A
- Wireless Network: Dual-band Wi-Fi
- Network Kill Switch: N/A
Wi-Fi
- Operating Frequencies:
- 2412 MHz - 2472 MHz, 5150 MHz - 5850 MHz (FCC/CE)
- 2400 MHz - 2483 MHz, 5150 MHz - 5850 MHz (SRRC)
- Wi-Fi Transmitter Power (EIRP):
- 2.4 GHz: <23 dBm (FCC); <29 dBm (CE/SRRC/MIC)
- 5 GHz Band1/2: <23 dBm (FCC/CE/SRRC/MIC)
- 5 GHz Band3: <30 dBm (CE); <24 dBm (FCC)
- 5 GHz Band4: <23 dBm (FCC/SRRC); <14 dBm (CE)
- Wi-Fi Protocol: IEEE 802.11 a/b/g/n
