Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Background
The Astro A50 Gen 5 is a wireless gaming headset and charging base designed to switch audio between three connected gaming systems. The base connects to consoles and computers through USB-C, and the headset's Playsync control changes the active system. It uses Pro-G Graphene audio drivers and a 48 kHz boom microphone.
Identification
The fifth-generation A50 is supplied with a Playsync Audio base that connects three gaming systems through USB-C. Confirm the generation and base-station connections when comparing it with older A50 models or the A50 X; the shared A50 name does not establish repair compatibility.
Technical Specifications
Audio:
- Drivers: 40 mm Pro-G Graphene
- Microphone: Omnidirectional; 60 Hz to 20 kHz; up to 16-bit/48 kHz sampling
- Headphone frequency response: 20 Hz to 20 kHz
Connections:
- Wireless: Lightspeed
- System inputs: USB-C connections to the base
- Switching: Three systems through Playsync Audio
- Base USB-C ports: Three device inputs and one power input
- Base power adapter output: 5 V DC / 2 A
- Base Bluetooth: 5.0 + LE
Dimensions and Weight:
- Headset dimensions (H × W × D): 91.5 × 185.8 × 184.9 mm
- Headset weight: 375 g
- Base dimensions (H × W × D): 40 × 123.4 × 147.7 mm
- Base weight: 305 g
Power:
- Battery: Rechargeable lithium
- Rated battery life: Up to 24 hours at 78 dB; varies with use
- Charging: Base dock or USB-C; headset USB-C is charging-only
- Full-charge time: Approximately three hours
