Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Troubleshooting
If your Apple TV 4K is not functioning properly, check out the troubleshooting page.
Background
The Apple TV 4K (3rd generation) was released in November of 2022 as a successor to the 2nd generation model released in 2021.
This new model reduced the size, removed the cooling fan, and upgraded to an A15 Bionic processor.
It was available in two versions: A Wi‑Fi only model with 64 GB of storage, and a model with Wi‑Fi and Ethernet with 128 GB.
Identification
The biggest visual differentiator between this model and the 2nd generation Apple TV 4K is the absence of "tv" text on the top cover. It's also slightly smaller, and features no external cooling vents on the bottom cover.
The included Siri Remote has a one-piece aluminum body with a power button, ring touch enabled clickpad, and Siri button on the right edge. It also has a USB‑C port instead of Lightning.
Technical Specifications
Hardware
- CPU: A15 Bionic Chip
- Storage: 64 GB (Wi‑Fi only) or 128 GB (with Ethernet)
Connectivity
- Wireless
- Wi‑Fi 6 (802.11ax) with 2x2 MIMO
- Bluetooth 5.0
- Thread networking technology
- IR receiver
- Ports
- HDMI 2.1, 18Gbps speeds
- Gigabit Ethernet (optional)
- Built‑in power supply
Siri Remote Specs
- Bluetooth 5.0
- Microphone
- IR transmitter
- USB‑C port
- Rechargeable battery
Dimensions
- Apple TV:
- Height: 1.2 inches (31 mm)
- Width: 3.66 inches (93 mm)
- Depth: 3.66 inches (93 mm)
- Weight: 7.5 ounces (214 g) with Ethernet, 7.3 ounces (208 g) without
- Siri Remote:
- Height: 5.35 inches (136 mm)
- Width: 1.38 inches (35 mm)
- Depth: 0.36 inch (9.25 mm)
- Weight: 2.3 ounces (66 g)
