Guides
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Anker Soundcore Boost A3145 is a portable Bluetooth speaker designed for high-performance audio. Many users describe it as having the best balance of loudness and quality suitable for various environments, from indoor to outdoor. Moreover, it is compatible with any Bluetooth-enabled device, such as smartphones, tablets, and laptops; the NFC pairing feature ensures a quick connection with Android devices.
It is an upgrade from its original Soundcore 2 A3105 featuring BassUp technology. Some of the upgrades are: updated from Bluetooth 4.2 to Bluetooth 5.0; switch from Micro-USB to USB-C charging port; enhance waterproof rating from IPX5 to IPX7 (fully waterproof). Moreover, it is the first in the series that has custom EQ supported by Soundcore app. It also has TWS (True Wireless Stereo) enabling independent left and right audio channels.
Identification
The Anker Soundcore Boost A3145 is a small, rectangular speaker. You can find the power, play, volume, and bass buttons on the top. On the side of the speaker, there is a port for charging. The name “Anker” is on the front of it.
Technical Specifications
  • Dimensions: 204 x 72 x 69 mm / 8 x 2.8 x 2.7 in
  • Input: 5V / 2A
  • USB output: 5V / 1A
  • Playtime: 12 hours
  • Waterproof rating: IPX 7
  • Weight: 585g (20.6 oz)
  • Driver (full range): 1.75” x 2
  • Driver (tweeter): 2 x 1”
  • Range: 20 m (66 ft)
  • Audio Output: 10 W x 2
  • Charging time: 4-6 hours
  • Battery capacity: 5200 mAh
  • Impedance: 4Ω
  • Frequency response: 70Hz - 20KHz
  • Bluetooth version: V 4.2
Source: Anker Soundcore Boost Manual
Additional Information
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 63
All Time: 415
