Documents
The 8BitDo Ultimate 2C Wireless controller is primarily identified by its Hall Effect joysticks/triggers, 1000Hz polling rate (2.4G), and dual mode functionality (Bluetooth for Android/Switch, 2.4G for PC/Android). To pair, turn on the controller, set the mode switch, and hold the pairing button for 3 seconds until the LED blinks rapidly.
Technical Specifications:
- Connectivity: 2.4G Wireless (PC), Bluetooth 5.0 (Android), and USB-C Wired.
- Polling Rate: 1000Hz (for 2.4G and wired connection).
- Battery: 480mAh Lithium-ion, ~32 hours play time (via Bluetooth), ~2 hours charging time.
- Joysticks & Triggers: Hall Effect joysticks and triggers for enhanced durability and accuracy.
- Compatibility: Windows 10/11 (via 2.4G/Wired), Android 9.0+ (via Bluetooth).
- Dimensions/Weight: 147 x 103 x 61.4mm / 218g
- Special Features: Dedicated mode switch, rumble vibration, and extra bumpers (L4/R4).
- Package Contents: 8BitDo Ultimate 2C Controller, 2.4G Adapter, USB-C Cable (1m), Manual.
