Shop the Holiday Gift Guide
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Land Rover Defender (L316) Technical Specs
Engine Evolution
  • 200Tdi & 300Tdi (1990–1998): The "bulletproof" mechanical era. These 2.5L four-cylinder turbodiesels (111 hp) are highly prized for having no electronic ECUs, making them immune to EMPs and easy to fix with basic tools.
  • Td5 (1998–2006): Land Rover's own 2.5L five-cylinder turbodiesel (122 hp). It introduced the first major electronic engine management system to the line, offering more refinement and significant tuning potential.
  • "Puma" (2007–2016): Sourced from the Ford Transit, these 2.4L and 2.2L engines brought a 6-speed transmission and better emissions compliance, along with a revised "modern" dashboard that finally included a proper heater.
Drivetrain and Chassis
  • Drive Type: Permanent 4WD with a two-speed transfer box and a lockable center differential.
  • Axles: Solid live axles front and rear, providing maximum durability and constant ground clearance over obstacles.
  • Suspension: Long-travel coil springs with hydraulic dampers (a massive upgrade in articulation over the leaf-sprung Series vehicles).
  • Brakes: 4-wheel disc brakes became standard during this era, significantly improving stopping power for heavy loads.
Dimensions and Body Styles
  • Defender 90: Short wheelbase (92.9 inches)
  • Defender 110: Long wheelbase (110 inches)
  • Defender 130: Extra-long wheelbase (127 inches)
  • Payload: Capable of hauling over 1,000 kg (2,204 lbs) depending on the configuration.
Author
with
oldturkey03
866,045 Reputation
123 Guides authored
Global Fixers Member of Global Fixers
Community
72 Members
3,060 Guides authored
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 106
All Time: 557
