Why isn't my beater bar spinning?
The beater bar isn't spinning, the belt seems fine, the suction is good. The filters have been cleaned. I've had the vacuum for about 5 years and never had an issue until now. It also doesn't want to stand upright--but this could be an unrelated issue.
5 Comments
" It also doesn't want to stand upright "In my case the DC14 works fine but will not stand up on its own,.which makes it difficult when using the hose attachment. Please advise
by Frank Dampf
The belt is still tight but will not turn when on.
by William
Mine will spin for 30 secs then stops, I turn it on and it keeps doing the same.
by Thomas Pilgrim
he most common reason why the brush roll on a Dyson DC14 Animal (2004) is not spinning is that the belt has become loose or has broken. The belt can be accessed by removing the soleplate from the vacuum. Once the belt has been checked and replaced (if necessary), the brush roll should start spinning.
by Derek Mullins
@dadibrokeit
how do i adjust the suction to my Dyson DC14 Animal (2004) with image
by Derek Mullins
