Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1498 Questions View all
bottom half of my iPhone won't work
I dropped my iPhone and now the bottom half won't work, but the top half will. What do i need to replace to fix it plz
Add a comment
1 Answer
Chosen Solution
If you mean it wont work because it does not respond to touch, it is most likely the digitizer. Depending on if you still have your 1 year warranty through apple active depends on how you should proceed.
If you do still have it active, bring it to apple, and they should replace it for free (if there is no sign of damage).
If you do not have your 1 year warranty active still, you should check ribbon 2 to make sure it is fully connected. If ribbons 1, 2, and 3 are all connected properly and it still does not work you will need to purchase a new digitizer.
Add a comment
Add your answer
jason will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 2,877
