Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
iPhone 4 will not hold charge while plugged in a computer?
Hello,
Recently my iPhone 4 stopped holding it's charge while plugged into my computers. I have tried different USB ports on my work computer and my laptop at home and encounter the same problem. I used the same cable for all occasions. It will however hold charge once its plugged into the power adapter.
I have made a few repairs to the iPhone but I don't believe i've moved the Dock Connector, so it may be a problem with the Battery? I also lost my Pressure Contact (The clasp that goes over the battery connector) and had the iPhone running for a few weeks... not too sure if that will cause any damage? I found it a couple days ago and put it back in... no change.
I am considering replacing both the Dock Connector and Battery but I would like to try and solve the mystery first :)
Any thoughts/recommendations?
Score 1
Add a comment
1 Answer
Chosen Solution
Dradeel, sounds like the battery to me. The AC adapter supplies about 1 amp to the phone when charging, compared to the USB port's 500mA. I'd start with the battery and make sure your contacts are clean and appropriately seated. If that does not help, then you can look at the dock connector as well as charging circuit. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Dradeel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 604
