Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3252 Questions View all
I can't turn up or down the volume
I changed the battery the other day because there was water damage in my iPhone. The repair went well, but when I turned on my iPhone, I couldn't hear any volume. When I go to the settings, then sounds, and I turn up and down the ringer and the alerts I can hear. I suppose there is a problem with the speakers, because I restore it and it still doesn't work. So what do I need to do???? I would like to load a picture, but it's not allow!!!
Thanks
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
You most possibly need a new charge port.. It probably got water on it, causing it to be damaged and now it is not letting the music actually get to the loud speaker
Add a comment
Hold down the home button and then try your volume it worked for
Me
Add a comment
Add your answer
daymamie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,729
