PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
Won't Turn on?
I have a controller that won't turn on or charge. I put a new battery in it that I know works so I didn't have to buy a new one and it still doesn't work what do I do?
Add a comment
1 Answer
Most Helpful Answer
Hi!
Was the new battery you put in, already holding a charge?
If so, it's most likely related to the motherboard...
You could replace the USB/LED board together with the cable to see if that is it, but most likely it is the motherboard.
Guide: DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement
Otherwise I would check the motherboard and check it for shorts. Otherwise a motherboard replacement may be required.
Sorry!
Score 1
Add a comment
Add your answer
Adam Lovette will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 31
All Time: 29
