Repair and disassembly information for Logitech's G522 Lightspeed wireless gaming headset.
Why it cannot charge properly?
Why it won't charge properly? It keeps connect and disconnecting many time.
1 Comment:
If yours is covered under a 2yr warranty, Logitech should honor repairs free of charge. This presumes the charging adapter, connector and headphone connector aren't damaged. Outside of warranty; try using the Guide tab to disassemble yours if the battery is worn out.
by
Add a comment
1 Answer
the charger cant supply enough current or the headphone it drawing more current than it is suppose to.
Sub a good charger or try ur chgr on a diff headset. - it could also be the cable.
If it is the headset, it will have to come apart and determine if it is a replaceable part that will fix it.
Add a comment
Add your answer
Muhd Nur Akbar will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 35
Past 30 Days: 119
All Time: 119
