Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
Shuts off, when plugged in says there is no battery
Iphone intermittently works and then shuts off. When plugged in, it says there is no battery and then says it needs to be connected to iTunes to be configured. Then it will work for a day or two and repeat
Score -1
Add a comment
1 Answer
Chosen Solution
sounds like a bad battery...iPhone 4 Battery Replacement. It's a simple and cheap repair that anyone could do. Go easy on the battery connector it's easy to use too much force and pull the connector from the board.
Score 1
Add a comment
Add your answer
Pat Doran will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 792
