Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
Everything replaced. Keyboard doesn't work
You know, I've been so dedicated to fix this %#*@ thing. New battery, new logic board, new bottom case with new keyboard (got two because first one was bad). new trackpad, new cables and yet...... the keyboard STILL doesnt work. At this point, with money sunk into this....I guess its just ready to retire. Not sure if anyone has had this experience, but its been pretty frustrating. Everything else works fine otherwise.
Mouse works fine... power button works fine. Just been the keyboard. I've gone through every variable I could think of.. at this point I have no clue what else there.
Add a comment
1 Answer
It is likely that the very fragile cable from the keyboard / Track pad is either not fully connected or latched down or it has been damaged which is very easy to do on these models. Be careful it did not overheat from something not fully connected or whatever as then it is truly game over as there is no cooling fans on these models and the CPU will overheat & eventually short out. I have one here that suffered the same plight.
Add a comment
Add your answer
Andrew will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 76
