Find solutions to your computer repair questions.
21219 Questions View all
Reinstalled Windows XP ,missing some drivers with the new install
Old hard drive failed,so I bought a new one.I had a copy of windows xp ,so I did a fresh install.But some of the drivers were not replaced after the fresh install.The following drivers are missing(Ethernet Controller)(Multimedia Audio Controller)(PCI simple communications controller)(RAID Controller)Does anyone know where I can find them to download?
Score 2
Add a comment
Most Helpful Answer
Hello Vernon!
Which computer do you have? You should be able to go to visit the company's website and download the drivers for you're computer model.
Score 1
1 Comment:
This was rig made from the ground up for me.No real specific brand of PC.Is there someplace I can look in my system to see which manufacture to use?
by
Add a comment
vernon, check for any marking or numbers on the motherboards. If you can not ID the motherboard from any distinct markings, I would suggest software like like thisIt will give you the details about your hardware. From those result, you should be able to get the drivers, either from the manufacturers website, or by doing a Google search. Hope this helps, good luck
Score 1
3 Comments:
I will look at the motherboard and see who the manufacture is.This is a great help,I'll let you know what I find out !
by
Found the model number and went to the manufacturers web site and got the drivers!!!!!!!!!!Thanks for info it was spot on !!!
by
Good Job, congratulations on getting it done:-)
by
Add a comment
check out driverrobot.com if you ever are missing a driver it will find it and allow you to download them.
very good product for windows
Add a comment
Add your answer
vernon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,014
