2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
Flash Storage Firmware Update Won't Install?
I was previously using this device with a 1TB Samsung 970 EVO NVMe SSD & a Sintech Adaptor. I replaced the SSD with it's original shipped Stock Samsung 512 GB SSD with a clean installed Monterey OS & I had this update pop up. No matter what I try it keeps coming back (PRAM / SMC Reset). I have never seen this 'Update' Before.
I never tried this method yet just wondering if there is another method possible, the system is running nice and smooth apart from this 'issue'. It seems that I will need to do a clean install again to resolve this. @danj Any Idea on how to 'resolve this'?
UPDATE 06/04/26 I booted externally into Catalina & then Monterey (Internally & Externally). I Clean installed Catalina externally & booted. I used OCLP to install Sequoia but STILL we have the firmware update which does not install. I guess we have to wipe the SSD (Original 512 GB SSD from the unit) which is still installed, and clean install either El Capitan or Monterey to see if that clears the issue.
Add a comment
1 Answer
Bootup under High Sierra as Monterey might be getting in the way.
1 Comment:
OK I can try that using an external drive that I have a HS installation on! OR did you mean to install HS fresh? HS & Catalina had the firmware updates included in their installers AFAIK, either way I have every OS on an external drive at hand for testing. I will try it when the owner returns in 7 days to collect their hard case. Update then.
by
Add a comment
Add your answer
livfe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 100
