Question Closed
Won't Start/Boot Black Screen, high spinning fans
Hi, I tried to read through every answer I could find on the 20" iMac g5 isight. -A1145.
Based on what i read I have reset PRAM, SMU, and replaced the power supply. Same problem.
When the power button is pushed the light on the front (lower right corner) lights. I hear a faint spinning, (HD, Optical Drive, fans????) The screen stays black. After a minute or so, the fans spin really fast, but nothing else but black screen. It stays stuck in that mode indefinitely. (at least it seems that way)
I could not find the led's some people have mentioned.
Any thoughts? Logic board maybe?
Thanks,
Add a comment
1 Answer
Most Helpful Answer
It is the logic board. I have the exact same model with the exact same symptoms and what causes it is the video card failing. (in some cases it is faulty capacitors) I did a reflow of the graphics card on mine and it worked for about 5 months before going back to vegetable state. The only way you can truly fix this is to get a new logic board. If you google search ho to reflow a chip then you can try that but it is not a very long lasting solution and in some circumstances can damage the board more.
Hope this Helps
Score 1
Add a comment
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 1,186
