Officially released on November 10, 2023. This is budget-friendly smartphone boasts a large 6.74-inch display with 90Hz refresh rate.
Why I can't put the charge in the phone
Why i can't put the charger in the phone
Add a comment
1 Answer
Your charging port is likely dirty or damaged. To clean it, I recommend these steps.
  1. Take a dry soft bristle toothbrush (Do not use water!) to brush out dust and debris from the charging port.
  2. Add 90% Isopropyl Alcohol to the brush for harder debris.
If this doesn't work, the other steps you can try are:
  1. Try a different cable.
  2. Replacing the charging port.
Replacing the charging port should be a fairly simple job on this particular device, I'd find a trustworthy online guide (IFIXIT does not have a guide for this model.) or take it to a local repair shop.
Add a comment
Add your answer
omar will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 6
Past 30 Days: 6
All Time: 6
