The Husky Air Compressor H2G3TK is a portable, corded electric air compressor with a 2.0 HP motor, 2.6-gallon tank, and a maximum pressure of 135 PSI. This page provides detailed information and repair guides for this compact, 30 lbs compressor, suitable for light-duty tasks and equipped with control regulators.
Compressor doesn't start?
Give the replacement motor part number which isn't listed. But the motor is shown. Thanks 👍 😊
Score 1
Add a comment
1 Answer
On the diagram this
would be a pressure switch. That would be the second thing to check after the on/off switch. You should be able to see resistance on the 2 terminals of the power plug with the on/off switch on. If not, short out the pressure switch and see if resistance shows - it should be relatively low, 1-5Ω.
If there is no reading then you might have a bad motor. Try reading directly on the motor leads.
BAsically.
Troubleshooting the Motor:
If the motor doesn't start, common checks include:
  • Confirming proper power supply (breaker/fuse).
  • Checking for proper extension cord use (avoiding overly long or thin cords).
  • Letting the motor cool down if the thermal overload has tripped.
  • Issues with the pressure switch or internal components like reed valves or brushes if it runs but doesn't build pressure.
1 Comment:
Could also be a bad capacitor....
by
Add a comment
Add your answer
SON'S 360 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 48
All Time: 317
