Repair and troubleshooting documentation for Frigidaire dishwashers.
Model FFBD2411NS6B panel lights all ok but won't run
No sign of life other than panel lights all respond to touch. Not in any kind of lock or delayed start mode. Tried powering off for several hours, still won't run when power restored. Door latch seems solid. Removed, inspected & reconnected all cables from control module. Inspected both sides of control module, no burnt smell or signs of damage.
Add a comment
1 Answer
Most Helpful Answer
Hi @arby28329
Here's the 1st part of the the service data sheet for the dishwasher.
Check if you can initiate the Water/Service Test whilst in idle mode as shown by the sheet and check what happens when trying to step through the various tests.
If the problem is due to a faulty part that needs replacing, here's the parts list that is useful.
Locate the wanted part in the list and note the part number that is shown for the part. Search online for the wanted part number only, to find suppliers that suit you best.
Here's the 2nd part of the service data sheet that will help with any disassembly etc.
Score 1
Add a comment
Add your answer
Arby will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 11
