Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Replaced Screen Now edges don't respond
I recently cracked my 3gs screen and ordered the replacement kit and changed it. After replacement (in the upright position) the letter "P" does not work. If i turn it sideways it works. Almost like the edge of the screen doesn't work. Is there a calibration for this? I have dissassembled and reassembled and checked connectors, which appear ok. Thanks in advance.
Score -1
Add a comment
1 Answer
Chosen Solution
Check your digitizer cable connection. It sounds like you have a loose or bad digitizer connection. If not, it could be a faulty digitizer and you may need to get your screen replaced.
Again, check your connection to make sure it is making good contact with the mainboard connector.
Best of Luck,
Add a comment
Add your answer
Tim will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 391
