The Nokia E71x features 3G, Wi-Fi, Bluetooth, GPS, and a 3.2-megapixel camera.
2 Questions View all
How to repair the connector for power adapter (in phone)
The problem with my Nokia E71 is that the power adapter connector in phone doesn't fit exactly (It loose).
Power adapter is tested in multiple Nokia phones and it is working OK.
So I should change the power adapter in phone.
In what part is the adapter?
Comments:
is it an E71 or E71x
by
this will show you how to open your phone Nokia E71x Motherboard Replacement
by
Add a comment
1 Answer
Chosen Solution
If it's an E71 and I assume is same as E71x, then just look on ebay for a replacement power adapter socket. You'll need to find other vids on taking the E71 apart but it's easy to replace the socket. Had same issue on mine but I replaced doing the above.
Issue is getting the casing off and back on without cutting the ribbon cable that is on the right hand side of the phone. I've nicked mine but appears to be just related to the volume. So got a working power socket but now can't turn the volume down :)
Still, was worth it to replace the faulty socket.
Add a comment
Add your answer
Late will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 2,248
