Repair guides and support for your Panasonic microwave.
Panasonic NN-SD27HS works only for 2-3 sec. false overheating error?
Hi,
this is my first question here.
My Panasonic NN-SD27HS performs very annoing error for quite a while.
It works perfectly ok, but with no reason sometimes it stops working after 2-3 seconds. Magnetron and turntable are off, only overheating fan is on for next 2 min.
Seems like defective temp. sensor, but this malfunction appears/disappears with no explanation...
No error code is displyed...
sometimes it helps, if I reduce the power to 440W
Can it be a kind of loose contact around the temp. sensor, or a capricious door switch mayby?
really no idea where to start checking....
Add a comment
1 Answer
Most Helpful Answer
Hi @jaro77159
Here's the service manual that will help.
Go to p.18 Sect. 9.1. (Troubleshooting) Oven stops operation during cooking, to see the possible causes for why cooking stops within 3 seconds of starting
Score 1
Add a comment
Add your answer
jaro will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 43
