Released in March 2022, the Turtle Beach Stealth 600 Gen 2 Max wireless gaming headset can be identified by model number **TBS-2360** (varies by platform and color).
Turtle Beach Headset isn't turning on
My brother ripped ou the microphone wires so I thought I would try to just replace them. In the middle of the process I tried to turn the headset on but with no luck there was no power. I tested the battery and its still good. When I try to charge it, no light shows. Any idea what is wrong? I have not resoldered the mic to the board yet.
Add a comment
1 Answer
@greenhusky check the black wire on P4. It does look like it has been damaged and may no longer make a connection. I would unsolder it, cut 1/4' of the length, strip the insulation and resolder it.
2 Comments:
Thanks for the suggestion, but even after reconnecting the wires and adding the mic wires, there is still no power
by
@greenhusky time to follow the power traces on your circuit board. Use a multimeter and just follow the traces from the battery and see if there is a place where you just have no more power. Multimeter in VDC (like 10VDC) Black probe to Negative and keep probing the traces for the Positive connection with your Red probe.
by
Add a comment
Add your answer
Mel Kamar will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 18
All Time: 69
