Adamo 13 - Power cable OR power jack problem?
I will try to be articulate, but may be overtly verbose in trying to explain the issue:
I am having trouble with charging my adamo - I suspect it is the power jack itself.
When I plug the power cable into the power jack, it does not always charge or make a connection. I can see from the battery icon when it has connected.
When I plug it in and the icon for the battery does not activate the battery icon with a plug next to it, I can often manipulate it to charge by applying pressure to the outer base of the power cord while it is plugged in. Unplugging and re-plugging don't seem to make a difference.
What do you think the issue is -- and can I fix it?
Thank you for your time!
1 Comment
cate, I've got exactly the same problem. Very keen to hear how it goes.... Also, where did you get your replacement part from? I can't find any online.
by bob12321
