Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
Question Closed
iPhone won't turn on
So my iphone 3g was working fine apart from the battery ran out very quickly. So I tried a DIY battery replacement. Once I'd put the phone back together everything was working properly. I then did a test call and realised nobody could hear me and I couldn't hear them so i figured the microphone and audio piece needed replacing/repairing. I opened the phone back up to have a quick look if all the cables looked ok. cable 3 wasn't in the correct place so after doing this I put it in and put the phone together again. I turned it back on and it was still in the same condition (all working ok apart from the mic and audio piece) So again i went to look inside, put it together again and now it wont even turn on!! does anyone know what this may be? I hope someone can help :)
Add a comment
1 Answer
maybe your phone has been over heated or when you looked at the cables maybe one is missing ? ...
atleast try hold the turn off button and the menu button for 8 seconds and the keep hold of the menu button but make sure its connect to your computer
1 Comment:
unfortunately this isn't working :( itunes isn't picking it up either. thanks anyway and do you have any more tips?
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 375
