Why does my washing machine pause early in it's cycle?
My Samsung washing machine pauses a few minutes in to cycle once water is dispensed into the drum. I've experienced the uneven laod issues towards the end of a cycle and it's not that. Followed a load of trouble shooting. Waste is clear, filter is clear, water inlet is clean. Its as if it won't spin once the weight of the water is in the drum. I can sometimes get it to complete a drain and spin cycle when empty. I've also run a recalibration. Samsung have been beyond unhelpful as its out of warranty. Tried a local independent engineer but he was old school and couldn't give any insight. Any help/suggestions would be greatly appreciated.
2 Comments
Hi @geraintstone,
Are there any codes being displayed when this occurs?
by
No error codes, just freezes, then pauses before turning off. Turn it back on and is in pause status. I ran the diagnostic cycle and had an error during the high speed spin check. I think the code was 3c2. Any advice for this? Thanks in advance
by
Add a comment
1 Answer
Most Helpful Answer
@geraintstone
According to the service manual there's no 3c2 code.
There is a 3C code (see p.37) although there seems to be some confusion in the manual as to whether it is a 3C or 3E code as there's no mention of a 3C code in the code table (see p.33) but 3E is mentioned in the explanation of a "3C" code on p,37.
Perhaps worth looking at all the same as it does seem relevant to the problem.
Score 1
Add a comment
Add your answer
Geraint Stone will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 68
