Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
replacing battery, bottom logic board overheats
I have a ipod touch 4 that has a dead battery.
I tried to replace the battery and made sure that the contacts are not bridging... however once I solder the +, ground and negative contacts the board starts to get really hot! i immediately de-solder the battery.
Is the battery bad?
What would cause the board to heat up? thank you.
Score -1
1 Comment
Also I am able to power the device on via usb cable and it works fine.
by
Add a comment
Chosen Solution
tony tony, definitely check on your soldering. It does sound like you are short circuiting something. If your work is done properly , I would suspect you have a battery with a short circuit. Replace it and see if it makes a difference.
Score 1
1 Comment:
I am getting the battery exchanged. I cleaned off the soldering and waiting for the replacement in the meantime. Thank you again.
by
Add a comment
But I still can't find the processor speed~
3 Comments:
Alex, did you post this to the wrong question:-) ?
by
These are 1GHZ A4 processor underclokced to 800MHZ last time i bothered to check
by
Does this in any way pertain to the above question? I seem to be missing something....It looks to me like Alex comment was meant for this http://www.ifixit.com/Answers/Ask/iPhone...
by
Add a comment
Add your answer
tony tony will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 666
