Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
414 Questions View all
no boot, no light on power supply, no charge on battery
first thought macsafe adapter because it had no light. tried a known good adapter, same. reset pram, smc, tried to boot w/o battery. got the light of adapter ti light, but no boot. exchanged ram modules for known goos ones. same result.
ideas?
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
I have experienced similar problems with MacBook Pros in the past. I find that it is the DC-In board within the computer. The result of this is that no power can reach the computer therefor it cannot charge, and if out of charge, it will not respond to anything. What you need to do is replace the DC-In board which can be found here:
MacBook Pro 15" Unibody (Late 2008/Early 2009) MagSafe DC-In Board
Now, this may take some work to install but if you are careful and do it correctly, it will most likely (fixed every one I had this exact problem with) fix your problem.
Hope this helps.
Add a comment
Add your answer
gladys mendez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,760
