The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
DSi "The device inserted in the SD Card Slot can't be used."
As the title describes, the DSI unit I'm working on isn't able to read SD cards, displaying the following error when trying to access them via the Camera app. Here's what I've done so far:
  • Replaced L/R/SD card flex cable with new cable.
  • Swapped DSI backplate (with flex cable) with a known working system.
  • Tried several SD cards, re-formatted both with the standard file explorer and the official SD card formatter. Can confirm full function with known working DSI.
At this point I'm almost certain it's a motherboard problem. Based on the rust in the system, (none on the flex cable contacts, mainly on the game cart reader) I'm willing to bet it's suffered water damage and now the motherboard can't read SD cards at all.
At this point I would just go ahead and perform a motherboard swap, but my client specifically wants this board fixed to get their childhood photos off the unit. As far as I know, the SD card is the only way to go about doing that, right?
Two questions:
  1. Is there any chance I could fix this problem on the motherboard?
  2. If not, can I get the photos off the device in any other way?
Update (02/12/25)
So I'm throwing in the towel on fixing the problem, but on a good note I figured out a different (albeit slow) way to get the photos off the unit. You can exchange photos over wireless within the camera app if you have another DSi. What I ended up doing was transferring all the photos from the broken unit via this method to an SD card in another working unit. I then transferred the files off the SD card to my client.
Score 1
1 Comment
Ah thanks for letting us know!! It's great to know that there is another possibility to get the photo's from the DSi!
by
Add a comment
1 Answer
Most Helpful Answer
Hi there!
Yeah, sound like a motherboard issue. I agree.
I don’t think it’s possible to get the photo’s off the DSi without SD card :(.
So it’s worth the try to get the motherboard fixed! First you need the schematic to see what is responsible for this.
You can follow this (I know it’s for the XL, but the IC’s do look near the same): Nintendo DSi XL Teardown
Scroll all down to see the IC’s explained. The IC which is responsible for the I/O or SD card slot is none of them. So it is something else, sorry.
What you can try is to clean everything, maybe doing a reflow carefully? It’s difficult to tell which component is responsible for the SD card reader.
Score 1
Add a comment
Add your answer
SelectStartRepairs will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 45
All Time: 969
