Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Question Closed
Can't remove internal screw to release battery
i am trying to change the battery based on the installation instructions here. I was able to get the external screws out (use the 5 point screwdriver) but the internal screw seems to need a Phillips. I am using a Phillips 00 screwdriver but can't seem to get it to move. I watched the video to make sure i was turning it correctly but still can't get it to move. Any suggestions?
Add a comment
1 Answer
Chosen Solution
I've had a bit of trouble with some screws, but ever since I bought the ifixit toolkit, they have the bit holder that has a hole in the end of it, once i placed the extender into the hole, I used that as sort of an extra torque to loosen the factory tightened screw.
Score 1
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 958
