Shop the Holiday Gift Guide
Released in April 2019. Model Number: A705FN/DS
doesn't work sound
when using the earphone and calling someone the sound system doesn't working just silent the whole sound
Score 1
5 Comments
@shimek does that happen when you plug the earphone into the jack or when does it happen? Explain exactly what you are doing. This could be a settings issue or a jack issue.
by Share
@oldturkey03 when am using the phone by earphone ,and if somebody calling to my phone will be silent
by Share
@shimek but it works okay when you use it without the earphone?
by Share
@oldturkey03 yes that good
by Share
@shimekeleme sounds like a bad headphone jack. Let's see if this is replaceable as a part.
by Share
Add a comment
1 Answer
Most Helpful Answer
@shimekeleme this sounds like your phone is having issues with the headphone jack. That jack is soldered to the daughterboard (charging board). I would suggest that you replace that board and then re-evaluate if it works. If not then the issue could be on the main circuit board.
Since iFixit does not yet have a specific guide for this, use the one from here It is written in Spanish so use a browser that will do the translating for you, if needed. Replacement boards are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Score 1
Add a comment
Add your answer
Hafiz Keleme will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 293
