The Kenmore Elite HE3 is a washing machine by Kenmore.
669 Questions View all
Why i'm I getting F06 code
washer stops and i get code F06......can't found what that mean
Score -1
Add a comment
1 Answer
Chosen Solution
Terry, here is my answer for a similar question:
" Here is what the F06 code stands for
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down.
If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the
Motor ControlUnit (MCU), and between the MCU and the Central Control Unit
(CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Make sure that the motor is working properly. It is the motor speed that needs to be tested if it does not work right, the washer will stop. Check the wiring diagram Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms.. You do want to make sure that nothing will impede the motor from working properly. Here is more info from here Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 - is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU. All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor."
Hope this helps, good luck
Score 2
Add a comment
Add your answer
Terry will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 667
