Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Battery issue resolved, now my exterior Buttons no longer work
Hello,
I replaced my first battery on my iphone 3gs.. but now none of my buttons work (volume, headphone jack, the button on the upper right)
I'm about to re-open it and see if I missed a step... Any tips on what connection I may have missed and/or broke?
Thanks!
Ryan
Score -1
Add a comment
Chosen Solution
as they are all on the same connector I would suggest that you have not re-connected it properly. It is the square connector top left of motherboard and I never remember the number..it's 5 or 6.
Score 2
1 Comment:
thanks for the info! Hoping to try it and take a look later in the week
by
Add a comment
I would suggest checking to see if the actual logic board is seated correctly, if slightly out by even millimetres it can do similar things. I don't mean by lining up holes with a slight twist to either left or right, I actually mean lower in say left top corner and rear right corner sits higher. It will still work as normal, but you may notice that the SIM card won't quite sit right when you try to push it in.
1 Comment:
Thanks for the comments..I tried it last night, and I didn't have #5 connected all the way... all good now!
by
Add a comment
Add your answer
ryanheuett will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 10
All Time: 458
