Repair guides and support for your Samsung TV.
2620 Questions View all
How do I replace the samsung TV DLP (61 inch) bulbs?
The lamp used in a DLP TV has a limited lifespan. For the best screen quality it needs to be replaced periodically.
After replacing the lamp, the screen quality will be bright and clear as new. How do I replace the bulbs and type of bulbs needed ?
Score 1
Add a comment
1 Answer
Chosen Solution
Since I am not sure which TV you have, you might want to check this site and see if it will work for your model. Hope this helps, good luck.
Score 1
4 Comments:
Thank you oldturkey. How to Change your Samsung DLP Lamp in 5 Minutes.
by
So did it work for you?:-)
by
Yes I took the bulb unit out. Worked out OK. I need to order new bulb & housing.........thanks
by
Excellent, congratulation to a job accomplished.
by
Add a comment
Add your answer
david kruger will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 2,505
