Launch Date: February 2018 System: Android 7.1.2
My Xiaomi Redmi 5 Plus is dead, won't charge, LED is blinking.
Hello, everyone! I searched up this kind of problem and I have the same problem with one question posted here. But mine is a little bit different. The last time I used this phone, my phone was frozen and wont turn off. The phone's heated (to the point of overheating) so I removed the back cover and removed the battery. Though the battery's not yet expanded but it has been my problem these past few weeks. It drains quickly and won't charge up to 100%. So I ordered new batteries.
While waiting for the battery, I tried putting the battery back in and turn on the phone but it won't. I tried charging the phone but the LED was only blinking. My charger was fine since I can still use it on my other phone.
Today my new battery is here. I put in the new battery and tried to tun the phone on but it won't turn on. I tried to charge it. The LED was only blinking. Can you guys help me?
Score 3
3 Comments
Yoqish knopkas
by
The system has been destroyed
by
@kgsjta if you are talking about your firmware then reflash it.
by
Add a comment
Most Helpful Answer
Sounds like a potential power delivery or battery connector/cable issue. I'd advise you try replacing the cable/connector for the battery first, if not you likely fried something on the board.
Score 1
1 Comment:
@arandomhitman yours is a very solid and good answer. Only slight weak part is "likely fried something on the board" We always want to try and help those that ask and if we suspect a "fried" component, let's try and figure out which one. We all need to work on things together to help everyone out. Remote repair like what we are doing here, will only work if we continue to support each other with our attempts. I look at it not as a competition but a collaboration. That is what makes us community. Continue to provide your excellent answers.
by
Add a comment
@moogibettoid first make sure that you let the battery fully charge. Once you know you have a fully charged battery, give it another try. If the results are the same, you do want to check the charging board. Make sure that you have the proper voltages going into the phone. I would even suggest that you consider replacing that board, just to rule it out as a cause for this. Since ifixit does not yet have a guide for that, use teh one from here It was written in Spanish so use a browser that will translate it for you, if needed.
Check the flex cable from the charging board to the main board. Make sure there are no tears, corrosion on the cable and the connectors.
If all of that is working properly and you verified that it is, then the issue can be related to the charging circuitry on your motherboard. You could check it against images like this
This is NOT an endorsement for the original poster of this image. It is only for illustration purpose.
and then measure the components according to the schematics. You could also check the test points around the battery connector and see what you get on those. Never an easy repair but there are always options. Of course, if this is above your skills or tools you need, you could consider finding someone who can do this for you. Going to be expensive :-)
Here are the Redmi 5 Plus Charging Schematic and here is the Component Layout to locate the components on your board.
One other thing. Do not forget to ensure that your software is properly installed etc. Faulty software can/will also interfere with regular operations like charging etc. You should always consider a factory reset, for as long as you have the original account information that you used when you first set up the phone. You will need it to gain access to your phone when you do perform a reset. Also, you will lose your music/pictures/SMS/contacts etc. from your phone. Let's hope you've backed that all up.
Score 1
1 Comment:
this. I'd go with Turkeys advice here.
by
Add a comment
Maybe the emmc was dead or the battery is so low (sorry my English so bad because I'm Indonesian)
Add a comment
Connect the charger with battery disconnected from the port inside the case, then when mi logo shows up, connect the battery to the port. I just revived my redmi 5 plus using this method because of blinking led light when connected to the charger with old battery, I replaced it with a new battery, flex cable and button of power and volume, charging port, overly repasted the inside and outside metals of the motherboard, flash pixelextended 3.0 android 11 stable, antutu score 171219. Cpu throttle test 20threads 5mins no throttle, 100 threads 5mins 95% max perf before throttle. Cold asf perform like a new device.
Add a comment
Batereya redmi
Add a comment
Add your answer
Moogi Bettoid will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 21
Past 30 Days: 106
All Time: 3,357
