Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
555 Questions View all
Mower wont start due to oil runnig out @ last mow.
Before the last mow i changed the oil and filter and i didn't push in the drain plug all the way causing all the oil to drain out, then the mower died. There are no leaks and it will turn over but wont start. I was wondering where i should start first to troublesoot the problem.
Score -1
Add a comment
1 Answer
Chosen Solution
justin, first off, all internal combustion engines have common things they need to function. Oxygen, fuel and a spark. Of course you are due for another oil and filter change. Close the drain plug. Check your spark. Check the timing, make sure your flywheel is properly aligned on the crankshaft. If you have spark, check for fuel. Check your carburetor, fuel lines and tank. Make sure they are all in working condition. Check your float and needle valve inside your carb fuel bowl. Make sure that you have plenty of air reaching your carburetor for a proper fuel/air mixture. Now you could get more specific answers if you can give us a motor model number and be more specific about what mower you have. As with anything, take your time and do one thing after the next. Do not get lost in the troubleshooting and start tearing things apart, be systematic. Hope this helps to get you started.
Score 1
Add a comment
Add your answer
justin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 660
