The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
Won't turn on
My laptop won't get turns on when I plugged in charger or plugged out. Even no indicating light turned on. When I press power button, don't get any response from the laptop.
Add a comment
1 Answer
This is a harder issue to solve. Try a different power supply for the laptop. If that didnt work, unplug the battery. A battery can short circut and cause the laptop to not do anything. You should be able to find a guide that shows you how to open up the laptop.
Add a comment
Add your answer
Rubaiyat Hiya will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 22
All Time: 143
