Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
ONLY turns on when plugged in (usb/power) - error 3914 & 1611
I can't get the iPhone to turn on without a cable connection.
When try to restore, I get error 3914 & 1611.
I don't have any previous backup file and want to restore it to factory or any other version.
Thanks
Score -1
1 Comment
I this a Jailbroken phone?
by
Add a comment
1 Answer
Chosen Solution
The power issue could be caused by a bad battery. Since it does work with USB and AC adapter, I would start there. Replace the battery. Also, make sure that the dock connector is clean (no bend, broken or corroded pins) After that try putting it in dfu mode then restore. you can get older firmware and instructions on how to install it from here. hope this helps to get you started. Good luck.
Score 2
Add a comment
Add your answer
itguy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 848
