Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
Question Closed
Replaced display, now won't turn on
So, My fiance broke her screen.. I got a replacement and put it back together, but pulled too hard on the cable, slightly ripped the touch cable.. all worked except touch..
So I ordered a new display. Meanwhile I took it apart again just to make sure, checked all cables, tried holding that rip together, nothing...
Problem is, somewhere in here I did something wrong I think... Because it stopped turning on. I thought I'd wait until the new display came, but doing the same thing.
I've tried plugging into computer (nothing), charging for a bit, hard reset. Just won't turn on. Anything I could be missing, or maybe damaged the logic board?
Going to triple check all connectors but think they're good.. Thought maybe putting the logic board in the oven for a short bit to reflow it. but just waiting for now in case somebody has a better solution...
Add a comment
I would check the Battery/ battery connector. Also Check the Dock as it may be that the connection may be lose and will not charge, therefore your iPhone won't turn on
Hope this Helps
Add a comment
tried additional battery. Connector looks good.. not sure what I'm looking for to be broken though. Seems to charge based on charge light coming on when plugging in (on charger)
Add a comment
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 1,137
