Logic board, SSD, battery 'knock' and staingate
Hi,
I am contemplating upgrading my early 2015 MBP 13" (2.7 Ghz, 8 GB RAM, 256 GB original SSD) in the following ways. Currently, it works fine, albeit a bit on the slow side, but I'd like to futureproof it before used parts (the logic board in this case) become even harder to find. I've done the usual things to keep it running smoothly (updates on time, clearing out the clutter etc). Currently weighing up if the upgrades are worth it.
- Swapping the logic board for a 3.1 Ghz 16 GB RAM version. Core clock speed doesn't seem to make that much of a difference to the GeekBench scores but doubling the RAM should improve day-to-day usage. I haven't been able to find numbers to back this up though.
- Swapping the SSD for a OWC Auro Pro X2 2TB. I've seen the I/O speeds referenced as twice as fast as the original but I haven't been able to find numbers for the original Apple SSD.
Has anyone done the above, ideally together, and what was your verdict?
Other things I'd like to fix:
- Battery 'knock' - I had the battery replaced a few years ago and I think it might be moving slightly inside the case. Anyone else encountered this?
- Staingate - post removal, does anyone have any screen protector recommendations?
Thanks!
