Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
iPod touch 4G sleep button broken. why isn't volume button?
Hi I surprisingly successfully changed my iPod touch 4th Generation screen by myself but when I tried to turn it back on, I found the sleep button was broken so I had to put it in the charger for a second.
I don't want to have to buy a new part or majorly open up my iPod again so what I'm wondering is, is the cable of the part ripped or is it an easily solved problem. From what I understand, the sleep button and the volume buttons are one part so surely if a cable was torn, they would both not be working.
Score -1
1 Comment
same thing happened to me have you fixed it?
by
Add a comment
Chosen Solution
I had run into the same issue and i figured it out!!!!
It was the metal spudger tool I was using. I noticed that ever since i bought the set from here I had the same problem with the lock button not working but the volume still functioning. I had never once had that problem before, and i have done a lot of these. I did some experimenting with iPods that were under warranty still and used the tool more and more sparingly. I believe the exact issue came from when I was removing the copper tape that secures the digitizer ribbon. When I would repair the iPod not using that tool at all except to remove that tape I still had that issue. I believe it is the metal conductivity. Solution, use screwdriver with a rubber handle.
Metal Spudger Set Image
Product
Metal Spudger Set
$7.99
Add a comment
My sleep button has now stopped working and I've been told bye the techs at radio shack said that they stop working because of over use.
Add a comment
Add your answer
Andrew will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,625
