Repair and disassembly guides for Mixers.
267 Questions View all
Why won't my mixer will not start in the off position.?
I have an older kitchenaid mixer, it has the raising and lowering arms. My mixer will not start when it's in the normal off position. It will not start spinning until it is in the 2nd to 3rd speed. It will run on the 1st speed when I start it higher and move it down.
Any ideas where my problem is? It is a great old mixer and I really do not want to replace it.
thanks,
Score -1
2 Comments
Karen Gonzalez, sounds like you have a switch issue. Any chance you would/could give us a model number so we can investigate better?
by
it is a K5-A. Looks like I also need the knob for the speed level. thanks!
by
Add a comment
Chosen Solution
Karen Gonzalez, this is what I found out about your mixer:
Trouble: Mixer runs on high speed only
Possible cause : Phase control (triac)
Remedy: Replace phase control
Download the complete service manual from here. It is very similar for all the KitchenAid mixers.It will show you all you ever wanted to know about your mixer. It may be possible to repair the phase control, let us know what you find when you have is disassembled. Hope this helps, good luck
Score 2
Add a comment
The only problem with the KitchenAid micer Service Manuals is that they do not address any models prior to those which have the solid-state speed control. The K5-A used a wire-wound voltage divider which is no longer made. The on-off switch was also very different.
There were two types of these switches. The first version was a toggle switch with a forked toggle. A pin on a lever engaged this toggle and turned the motor on and off. The mounting position of the switch affects how well the turn-on function works.
The second version used a "micro switch" which was also lever actuated.
These almost never need adjustment.
Therefore, I assume that your mixer has the first version of the switch.
You will need to open the mixer motor housing up. This is described in the Service Manual. But, since current mixers use an entirely different switch, it is of no help there.
Anyhow, once it is opened you will see the switch and it is a matter of loosening the nuts which hold it to the bracket and adjusting the switch back and forth (or in and out) until the toggle if flipped when the speed control is moved from off to the stir position.
If you would like a photo of the assembly, there is one on the Yahoo WACEM group. Search for "K5-A Wiring."
Score 1
Add a comment
Add your answer
Karen Gonzalez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 7
All Time: 3,286
