Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Question Closed
3gs replacement battery doesn't work
Hi,
I have replaced my 3gs battery by one with the same apn as the original (616-0433), but the new one doesn't charge or startup. It starts when i put in in the charger, but when you pull it out it turns off (although it says it has 75% battery)
I replaced it again by the original battery and then it works all fine.
Can you help me fix this problem?
Regards,
Korné
Add a comment
1 Answer
Chosen Solution
Korne, sound to me like you got a malfunctioning battery. I would contact the vendor where you bought the battery from and get another one.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 604
