Why won't my iPhone Charge?
A 32GB iPhone 4, GSM, AT&T
I did a screen replacement, along with the whole dock connector assembly (including speaker assembly). I also purchased a new, OEM battery from Canada (punctured the old one by accident.)
I pulled out the battery connector by accident when prying out the battery. I superglued it back in. The phone would not work without being plugged in. After fiddling with the connector a little, the phone started working off the battery again.
Now, the only problem is that the phone does not charge (tried both Mac & wall). It has been using battery (is at 32% right now), but will not charge. When plugging it in, the sound comes, and the bolt on the battery appears.
iTunes also says there is a problem with the iPhone, and recommends that I restore it. I want to avoid doing this as I will lose the unlock.
I thought the issue might be the battery connector, but since it is now able to run off the battery, that shouldn't be the issue, right? I don't have a soldering iron.
