Power supply isn't providing the monitor power
I'm having issues with my Infant Optics DXR-8 Baby Monitor.
My daughter knocked the monitor off a high shelf. I turned the monitor on, everything looked and worked fine. Later that night, while the monitor was plugged in and on, the low battery alarm started going off. I realized that the battery had not been charging even though the monitor was plugged in. For some reason, power from the wall (5VDC I think?) is not making it into the monitor, most likely (in my opinion) because something broke loose when the monitor fell. Has anyone had a similar issue? I'm going to open it up tonight and see if I can see anything obvious, hopefully I'll just need to resolder a lead, but I'm looking to see if anyone has any ideas if there isn't an obvious issue.
Flipping through the other questions on this site, I realized a lot of these monitors are USB charging. This monitor isn't USB, it's a 3.5 mm jack (or similar, maybe slightly smaller).
@khc5009 let us know what make and model your monitor is. Most common would be a damaged charging port. Post some good pictures of this once you have it apart. that way we can see what you see Adding images to an existing question
by oldturkey03
Thank you for the tip, I added the make and model, I'll try to add pictures when I get home.
by Kevin
