A power bank is an external battery for your device when you are unable to charge and need to charge a device.
500 watt Aukey Portable Power Station won't charge via any input
I have a Aukey PowerZeus 500 power station — a 500 watt lithium-ion electric "generator" device. When I got it, I couldn't get it to charge. It turned on, and I could power devices off the small amount of electricity that it shipped with in the cells, but no matter what way i tried to power it, it wouldn't register an input and eventually drained to zero.
Aukey sent me a replacement charger, but it didn't change anything. So they sent me a new unit, but declined having me send this one back (I assume they didn't want to deal with shipping lithium batteries a second time). The new one worked fine.
So now I have two units, a good one and a bad one. And the bad one has been sitting in the closet for a while now. It's as big as a toaster oven.
I've wondered if this is something that might be worth looking at internally. Could it be a simple fix? My instinct says no, hence it still sitting intact. But I am not sure what else I might do with this. Send it to e-waste? Any thoughts?
Add a comment
1 Answer
Based on what you described, this almost certainly isn’t a charger issue. Since you tried multiple chargers and the new charger works perfectly with the replacement unit, but this one still won’t recognize any input power, the problem is very likely inside the power station itself. The fact that it turns on and can discharge power means the battery isn’t completely dead. Most likely, the internal charging circuit or control board has failed. When that happens, the unit can still output power but simply won’t accept a charge.
I wouldn’t recommend opening it up unless you’re experienced with electronics repair. There’s a high-capacity lithium battery inside. If damaged or shorted, it can be dangerous and potentially cause a fire. It’s not worth the risk for a typical user.
Your safest option is to recycle it properly at an electronics or battery recycling center, such as a major retail store that accepts lithium batteries or your local hazardous waste facility. Don’t throw it in the regular trash. If you’d rather not waste it, you could list it online as “not charging, for parts only.” Some hobbyists or repair techs may be interested. Letting it sit in a closet long term isn’t ideal either, since lithium batteries can degrade or become unstable when left fully discharged for long periods.I hope my response has been helpful.
Add a comment
Add your answer
msenese will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 26
All Time: 200
