Repair guides and support for cars and trucks by Ford Motor Company.
1397 Questions View all
No electricity from wire plug to the spark plug on 2001 Ford Focus?
one of the cylinder of 2001 ford focus is not working .i found it out by pulling out each wire plug one by one and testing them .,to find out that one of the wire did not have power to transmit to the sprak pluge .
Score -1
Add a comment
1 Answer
Chosen Solution
faraj e, first make sure that the coil is getting the proper signal from the crank sensor. Check for proper ground to your engine. Make sure all the contacts are clean and check the wire to your sparkplug. Hope this helps, good luck
Score 2
Add a comment
Add your answer
faraj e will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 171
